Results 1 to 3 of 3
Thread: Open Loop???
    Advanced Tuner Blue02WS6's Avatar
    Jul 2006
    Central Florida
    319
    Open Loop???
    Can someone explain why when I set the "Fuel" "Closed loop enable" "ECT vs IAT" to max and set "MAF fail high" to 0, I still get info from the MAF while logging the VE as I got different numbers after I unplugged the MAF.
    2002 WS-6, Built A-4, 3000 stall, Lid and K&N, ported TB, 220/224, .551, 114 LSA, roller rockers, LT's, 2.5" true duals with X-pipe, Koni adjustable front and Bilstein rears with Hotchkis springs, front bar and bushings, welded SFC's, boxed LCA's., Midnight Blue trimmed in silver, silver face gauges, custom hood bird, HPT (with lot's of tuning)
    13,565
    I've followed this guide for tuning before, some of it is useless if you arent running a cam but to get it into sd it works.
    Also you can never log anything maf related in the table display if you are trying to run in sd.
    http://michigansnowmobiler.com/hptun...ons%20rev2.pdf
    Jul 2006
    Central Florida
    319
    Thanks for the link, I will check this out.
