Hi Guys,
I'm pretty new to the dodge stuff, hoping someone with experience can chime in. Vehicle is a 2010 Challenger SRT, 5 speed automatic. The ONLY modification is a BBK 90mm TB. The TB won't close enough to get idle down to stock idle values, but that's ok, I moved the desired idle to keep timing in check. The main issue is that when I floor it on the dyno (3rd gear for now) I will get a flashing lightning bolt (TB issue) on the dash. this doesn't happen every time. Once I got a P0121, once I got a P0122. I'm not sure if this is a bad TB out of the box, or if it's possible that the tune is the issue with expected air not matching actual airflow. I'm attaching the tune. If anyone with experience could comment I'd appreciate it.
