Hi guys,
I am totally new here and have no past experience with tuning so please bear with me. What I want to do is to set the ignition timing to 20 degrees ATDC. The reason I want to do this is to be able to use hydrogen based fuel like the output of an electrolyser cell. I looked at the demo version of VCM suite and it has many windows to set the timing advance and retard. But here I do not need to advance or retard (at least initially) but set static ignition timing to 20 degrees after the piston cross the top position. Because hydrogen burns so fast, the spark has to occur after TDC. Does the VCM editor allows to set the ignition timing in such a way? Can I also turn off the fuel injectors via some settings in VCM? because the hydrogen will be just mixed with air at the engine air intake so no need to use the injectors. My goal is to power the electrolyser with a separate battery and use the output gas as fuel and potentially get few hours of drive time. The power to the electrolyser (and hence the amount of H2) can be pwm controlled based on the accelerator position and engine load, which I think can be easily read from the j1939 CAN bus. Thanks in advance.
