Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: 2015 c7 afr ?
  1. #21
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by SultanHassanMasTuning View Post
    upgrade to LT4 pump and injectors
    meth kit is cheaper and gives way more headroom. LT4 injectors may still be too small....
  2. #22
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Use the dyno to show where max torque lies which I further assume to be Max cylinder pressure (is that a correct assumption Howard?) which is where I normally pull back the timing a bit than gradual increase to max HP. I more state these limits to be more for reliability, than for max power.
    Also the kits I have dealt with are 6-10 pounds boost only. I also use Dave Stecks 2 Injection Timing calculators to set and validate injection timing.
    Ed M
    [email protected]
  3. #23
    Mar 2010
    Texas Hill Country
    3,299
    injection calc works as long as you aren't out of injector. otherwise it pushes SOI way too early. more than 350 or so and you are spraying out the open exhaust valve with no way to tell how much of the injection is contributing towards combustion and how much is just going out the exhaust. wideband will read fuel (lack of O2) but it won't be coming from the cylinder burn.
  4. #24
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Quote Originally Posted by mowton View Post
    Ed M
    Correct. For zoning in on spark. Fuel control has become much more manipulating...
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
  5. #25
    Mar 2016
    CT
    19
    Quote Originally Posted by LS1408 View Post
    This is an A and A V3 kit with a 3.8" pulley. 16 to 17 degrees is what it seems to want. At 14 power drops off.
    mine loves timing...
    My 2016 c7 all stock with a procharger and meth and headers..went [email protected] lbs boost 17 timing
    so i add 1-2 more lbs if that with smaller pulley and lowered timing to 14 to be safe...made a street pass and car feels like a slug accelerates slow even my scan was jagged lol
    I dont use a dyno ..scan and datalog on the street
    Paul Ferrucci
    2016 Procharged C7 z51
    10.4@135 on 8 lbs of boost
  6. #26
    Jan 2022
    1
    sorry to bump super old thread. Where are you guys usually leaving timing on e blend (E40). I have one with a LT4 HPFP and injectors. INJ P/W is still around 5.2 ish and rail pressure hasnt dropped. I have it peaking at 18 deg close to redline with A&A kit at 10 psi. Unfortunately cant go off the knock sensors cause the texas speed headers are pressing up against the frame rail every time you press the gas (even in neutral) and causing fake knock -_-
  7. #27
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by Z3r0 View Post
    You will probably have to tune this with spark plugs.
  8. #28
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    I wouldnt go higher on timing.
    Damn im running 17* indicated. Have for about 3 years now. No sign of trouble. Plugs, valves, and rings look fine.
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
