Results 1 to 8 of 8
Thread: Fans not working is there something wrong with tune?
    Mar 2013
    8
    So I switched from 98 corvette to 99, and everything is working but the fans. . .
    Did I miss something in the tune?base tune new CPU (converted)+50idle.hpt
    Nov 2002
    Central Florida
    2,503
    I think you have failed to link the tune file, so no help
    coming there.
    There is a check-field for fan type (1, 2 e-fan or none)
    somewhere in the General stuff. I'd start there. But also
    check that your ECT is reading right (some detail diffs
    in how those ECT sensor(s) were set up, platform to
    platform, I don't know about 98:99 specifically). OS and
    harness need to match I think. But also do not neglect
    the simple, like fuses.
    405
    2,326
    The file is there. Fan settings look fine. Can you command them on with the scanner bi-directional controls?
    Mar 2013
    8
    How do I do that. I had already checked the fuses and relays, and I put a battery directly to the fans so I know the fans work, the fuses and relays are good.
    405
    2,326
    Quote Originally Posted by groundczero View Post
    How do I do that.
    With the scanner bi directional controls.
    Mar 2013
    8
    Wow, did not know that was in there I will try that tonight thank you.
    Mar 2013
    8
    Ok i tried this at home the low speed fan would come on as directed the high speed would not, but I think I have a bad motor there since it did not run as strong as the other one.
    405
    2,326
    They should both run low speed when Fan 1 commanded and both run high speed when Fan 2 commanded. Also leave Fan 1 on when commanding Fan 2.
