Results 1 to 6 of 6
Thread: p59 pcm 4.3 to 5.3 dbc conversion. idle stumbles when cold and also hard acceleration
    Jul 2015
    Oklahoma
    31
    hello, when cold start the idle stumbles if you try to accelerate. after it warms up normal acceleration is fine. but if you hammer the throttle it will fall on its face. im thinking fuel starvation? its a stock 2002 5.3 parameters tune for dbc. any help is appreciated.
    1971 k3500 suburban former rural ambulance. 4" lift, 35" BFG's, 5.3 4l80 205 d70f 14bff conversion in process...
    1978 Porsche 911 Rally car. 4" lift, 28" BFG's, 5.3 conversion in process...
    1993 Porsche 911 Carrera RS LS7 conversion in process... Road Racer
    1998 Chevrolet reg cab swb oem tx edition 20" wheels, 5.3 4l80 conversion in process...
    Jul 2015
    Oklahoma
    31
    here is my tune.
    Jul 2015
    Oklahoma
    31
    it seems to be getting better as i drive it a bit. is it learning?
    Jul 2015
    Oklahoma
    31
    anyone?
    Sep 2015
    31
    are your o2 sensors hooked up and working? any exhaust leaks? we will need a log also to tell anything.
    Jul 2015
    Oklahoma
    31
    i downloaded 3.0 and now i cant run my scanner???? my 02's are hooked up but i cant tell you if they are working cause i cant scan at the moment. also was tuning my wifes 2013 camaro ss and could not run scanner to check maf so i could tune properly. hptuners help?
