Results 1 to 6 of 6
Thread: VCM Writing Times
    Dec 2008
    on the Dyno
    1,825
    VCM Writing Times
    I do a lot of Gen4 Gen5 GM applications. Is there a reason flash times are WAY faster in 2.24 than 2.25? I can literally flash the ECM and TCM in 2.24 as fast as ECM only in 2.25.
    Sort of a petty question however time is money lol.
    Located in Central Kentucky
    ShorTuning
    Sep 2002
    Chicago, IL
    6,395
    2.25 uses much safer timing than 2.24, per the manufactures implementation.
    In some cases though, the timing might be a little too safe and will be adjusted town to reduce write times.
    We got this guy Not Sure, ...
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by LSxpwrdZ View Post
    I noticed that too. In my case it was only an additional 30 sec. or so on an E38 manual, but definitely noticeable. I just assumed it was for better error checking. The E40, by contrast, seems a little faster.
    Jaime
    Feb 2006
    South Carolina
    1,525
    A bit off topic, but has anyone reported "Read" issues with 97-98 LS PCM's.
    Jaime
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Quote Originally Posted by ElecTech View Post
    No
    Feb 2006
    South Carolina
    1,525
    No
    Ok, looks like I'll have to try and gather more information for you.
    I had a 98 Corvette fail to read using version .2855 (I think). It would hang half way through the read and then time out. I tried several attempts with the same results. 2.24 Read and Write worked just fine. This was the first 97-98 PCM Ive tried with 2.25 so I wasn't sure what the deal was.
    If I can still get access to the car, I'll try again with a more recent build and get any debug and info files I can.
    Jaime
