what would that command be 12.8 ,10.5 ,11.5 11.9 ?
Until you do, you will keep chasing your tail. PE works on top of the 1,000s of other calculations the ECU is doing in the background.
You misunderstand how PE works in this ECU.
If you are commanding a certain number and you are not getting close to it. Then the VE/MAF models are wrong.
You have to dial them in before you can command a certain number in PE. Otherwise you are just pulling the ECUs calculated number up or down some. You aren't actually commanding it. You're just kind of whispering in her ear and hoping she does it for you.
Leave it alone until you are ready to dial in the VE and MAF. If you find some crazy PE curve that manages to get you by for now, then once you retune the MAF and VE, you will have to completely redo the PE. Don't mess with anything until you are ready to do the VE and MAF.
well, technically, you should set your PE criteria and then tune your MAF and VE but definitely don't not tune your MAF and VE hoping to rely on huge fuel trims and a raped PE table to make it work. you will not like the results.
With your ve and maf tuned perfect your raping your motor with maf that's why gm commands mid 10 afr in there zr1.
Try it with A 8000 lbs suburban with many loads(constant) of 100 to 90 kpa ,pe all the time sure would be nice to be running 12.xx to 13.xx afr and not 10.50 afr
but we have to run 10.50 afr because we may go into more boost 12 lbs and need it.
All the pe ramp rates and criteria in the world will not fix that
Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
What's wrong is we are back to you don't know what you are talking about again. Whoever taught you to tune is a hack. What's wrong? It sounds like everything.... This is your thread, right? You started it to learn how to get the car to idle? The issue might not be in the idle tab after all.
Please don't be offended, but nothing is worse than someone asking how to do something, getting plain answers, then deciding the answers are wrong, and going about his merry business.....why ask in the first place?
Have you tuned your MAF and VE tables to zero fueling error or not? Because if you haven't (in this case in the idle and adjacent areas) then no amount of Idle tab editing is going to get your car to idle right.
My car idles great, btw. Blown 416ci cammed Gen5 C7. It also has exactly perfect fueling at every load/rpm/pedal combination. All the cars I have tuned are the same..... How does your car idle again?
Listen to us or don't. Your choice. We aren't here to argue with you, we are all here to help each other.
Looks like your here to put people down! This was my first gen 5 I have done ,I ask questions about idle because I knew these ecms where tq base,I have tuned 1000s of cars that idle great (INCLUDING THIS ONE)I have fixed many tunes from other shops all over US!
Tuning ve and maf tables are easy you should know that! Sorry most of the stuff I have done with boost is sd it fills in that closed loop to boost very well,
guess its worked for me with some cars running over 20 lbs of boost for 3 years on stock pistons and rods
one was in a s10 3rd highest boost car aka truck on lsfest dyno good old 5.7 drove it in pump gas with meth
Just did a 4.8 with 30 lbs boost stock parts
I see how you treat people... btw nice to see you know all later
sorry, but someone had to tell you. when your wounds heal come back and we can fix your car the right way. happy to help anyone who needs it and sometimes I need it, not ashamed about that.
but to come here and ask questions and argue about the answers is very immature and I am going to have to call that out.
