So in summary I'm comfortable to where my tune is. It slightly on the rich side, but I keep on getting knock counts. It is not Burst knock but rather the computer perceives it as the real deal. IMO It's totally random.
Here is everything I've done to try to remedy this:
-replaced a knock sensor
-Running stock timing values
-Stepped down to TR6 plugs @ .040
-stepped from 7.400 to 7.425 pushrod to quiet down valvetrain (verified w/ pushrod measuring tool). Preload is in spec too
-tune is slightly rich for safety margins
-Virtual VE is within 1% calibration
-MAF is usually 1-2% within calibration typically on the richer side
-Visual on old TR5 sparkplugs show no detonation / preignition etc
-audibly speaking I don't hear any detonation or pinging (Rocks in a can sound)
-predictive co-efficients disabled
-replaced fuel filter
-seafoamed motor
-ran fuel system cleaner
-ALWAYS run 93, this is not an isolated bad gas incident. Ive tried different stations
-changed oil
-engine not consuming oil or leaking into cyl
-purchased and calibrated new wideband (AFR 500) verified the unit LCD is within .10 AFR of analog out
This is driving me fucking insane. This is stock ls2 motor with cam and headers. Is there ANYTHING in here which looks remotely suspect for knock. I'm scared shitless to disable the knock retard or lessen sensitivity What's your guys angle on getting this fixed.
FYI wideband AFR is ac pressure sensor. 9+[PID.7101]*1.400
