Page 42 of 87 FirstFirst ... 3238394041424344454652 ... LastLast
Results 821 to 840 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #821
    Aug 2011
    Alaska
    566
    Hitting right or left arrow buttons on the keyboard will scroll you around. Holding ctrl+left or right will scroll in larger increments.
    Sonofabitch....... OK, that's cool. Screw the arrows. Time for a scanner 3.0 for dummies, apparently. I'll volunteer to be the test dummy. I won't even have to pretend.
    When arguing with an idiot, make sure he isn't doing the same thing....
  2. #822
    Sep 2002
    Chicago, IL
    6,397
    You can click and scrub all over the scroll bar now.
    Or just left click on the chart itself, then move your mouse over to the right, past the edge, and keep the left mouse button clicked..
    Based on your technique, i'd bet you missed KR before, or have to go over your data multiple times because of lack of focus, distractions, etc.. Scrubbing such a fine level like you do is really a bad way to do it.
    The proper way is to zoom out, find your issue, and zoom in.. you can do all of this from the mouse.
    We got this guy Not Sure, ...
  3. #823
    Jul 2012
    Italy
    219
    here the log. I have this problem with all logs files
  4. #824
    Dec 2014
    592
    See, that is where I disagree. After trying to the same thing in 3.0 that I do in 2.4, I actually *miss* more KR - either becuase I can't see it as well when zoomed out or becuase I can't move the "handle" smoothly enough with the mouse.
    Also, I did try holding the mouse button down and scrolling past the edge and it moves the graph data once and them stops, until I go back into the graph and move it past the edge again. I'd love it if it kept scrolling after moving past the edge - that is exaclty what I'm trying to go - keep the chart moving just by holding down the mouse button.
    The reason this is such a big deal for me is that the way my 'workstation" is setup, I did everything with the mouse in 2.24 - the keyboard is slightly out of reach with the way I have things setup now.
    Anyway, looks like I'll etiher have to change things (physical and/or software setup) or just keep using 2.24 scanner for now! :-)
  5. #825
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by jtrosky View Post
    Jiggle the mouse up and down and it will contiue the scrub. THe farther past the edge you move your mouse, the faster it scrubs.
  6. #826
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by ingsteve View Post
    That log opens and looks fine to me. Post a screenshot of what you're seeing.
  7. #827
    Dec 2014
    592
    Yeah, I know that "jiggling" the mouse makes it move, but that just doens't work going through a large log or logs! :-) Might be good for my hand/arm muscles, but not for tuning! :-)
    For now, I'll just stick with v2.24 - it works perfectly for my needs. I tried to use 3.0, but it just doesn't benefit me for my uses of the product. If I *need* to upgrade at some point (newer car, etc), I'll do that when the need arises.
    Thanks for the input!
  8. #828
    Jul 2012
    Italy
    219
    Quote Originally Posted by Keith@HPTuners View Post
    here a screenshot...i highlighed the 715,00
  9. #829
    Jul 2012
    Italy
    219
    i got it.
    There is still the bug for regional settings.
    If i replace , with . it shows correctly the AFR!!!
    See in the two pictures the difference in the decimal also on other values and chart (0,8 1,2...)
    Can you correct the bug for next version?
  10. #830
    Sep 2002
    Chicago, IL
    6,397
    I'm not following, where did you replace , with . ?
  11. #831
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    So when will 3.0 actually read codes from a 2016 Corvette?
    http://www.dsxtuning.com
    Just say no to bull s***.
  12. #832
    Sep 2002
    Chicago, IL
    6,397
    Do you see the DTC's in the VCM Suite info, in the controller info area?
    Feedback on this issue has also been pretty rough.
  13. #833
    Don't see LC1 as an option for Lambda, wasn't it listed in the older versions? Or has it only been AFR listed? I am now using 3.019
    thanks!
  14. #834
    Aug 2015
    44
    I don't have any 2016 Corvettes with codes currently, but I can go scan one and see what populates. I guess I could always unhook the MAF and set a code just to see.
    Anything specific you would like me to look for?
    Any other 2016 Chevrolet vehicles that you would like looked at. I have full access to all of them pretty much.
  15. #835
    Mar 2008
    St. Louis, MO
    4,860
    Nothin. Had a car on the dyno that would throw a code, but when hitting read DTCs, it wouldn't populate. DTC reading worked fine on a 2011 V though (same software build which is from this morning).
  16. #836
    Sep 2002
    Chicago, IL
    6,397
    Ok, so it works on some vehicles and not others. THat's good info.
  17. #837
    Mar 2008
    St. Louis, MO
    4,860
    Just checked my 2012 CTS-V, forced it to have a code, and it worked fine. Unfortunately, I don't have much else to test it on at the moment. I don't know if it's an E92 thing or a 2016 thing.
  18. #838
    Jun 2015
    3
    Anytime I attempt to export a data log in from scanner in csv format it shuts down the scanner and sends an error report. Message says "An item with the same key has already been added." Any suggestions? Just sent error report again. Thx.
  19. #839
    Mar 2008
    Paris, France
    435
    No Write Entire available on E40 ecm. (nor Vin/vats write)
    I need to delete VATS on a mail order.
    Is write calibration delete vats on 3.0 ?
    http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
    Check our Facebook page http://www.facebook.com/lsxcalibration.com
  20. #840
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by xxteacherxx View Post
    Post the log that you're trying to export data from.
