Page 48 of 87 FirstFirst ... 3844454647484950515258 ... LastLast
Results 941 to 960 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #941
    Aug 2015
    31
    any way to put the update version that is current on the customer page instead of just "3.who knows if I need to update"lol
  2. #942
    Sep 2015
    20
    I really wish I had a "Search prev/next" feature. Not sure how to request features, but..
    A "Condition" expression similar to what you see as "Filter" elsewhere would be brilliant, you can just call it "Filter" and most people familiar with HPT will instantly adapt.
    I would put it on a Ctrl+F (Find) accelerator, most users would naturally find it. It probably belongs under the Tools menu so "everyone" can find it.
    Why? I'd like to jump to well-known events for review (rather than watch a log play and try to eyeball multiple sensors on a graph), and I imagine most of the code to do the hard work (applying a Filter, setting playback position, etc) already exists.
    BTW V3 is so very nice, I think it's great work!
  3. #943
    Dec 2008
    on the Dyno
    1,825
    What about adding back the feature of load all data and clear all data for what used to be histograms. I know there is the zoom feature to only populate the data you are zoomed into however the old function of clearing the populated data would be nice rather than killing the scanner and starting a new log.
  4. #944
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by LSxpwrdZ View Post
    No longer needed. Scanner 3.0 automatically loads all data by default.
    We got this guy Not Sure, ...
  5. #945
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Please supply more info like post the Tune, Log and the Scanner details -- Channel and Main Layout (icon, word LAYOUT) located on the upper command line.
    You can import your old histograms into 3.0 by moving from the Graph sub folder, up one level to the VCM Scanner folder and then clicking on the HISTOGRAM sub folder. Find the histo you want to import and double click it. It will migrate to 3.0. There will be a warning "trying our best to get it all in", so check the parameter and axis values. You may have to update them. The parameters are found in the Parameter Selector table and the axis values are copy and pasted over from your VCM Editor tables. Put cursor on wither the x or y axis, right click, select COLUMN or ROW and copy labels. go back to GRAPH input screen and paste values. Make sure you have selected the correct parameter and it matches the one be logged in the CHANNEL table.
    Ed D
    [email protected]
  6. #946
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Logging Math Parameters
    How is a man suppose to log math parameters. You can't add them to the channel list? Can't even seem to be able to add them to a graph the only way I have found to log math is in a chart which does nothing for editing the tune. Why are the math parameters not in with the channel list/configs? Am I missing something here I am trying to do a simple Maf graph logging LTFT+STFT but there is no way to add LTFT+STFT to a graph
  7. #947
    Sep 2002
    Chicago, IL
    6,397
    Your screenshot shows you've added a math parameter to the graph.
    Your filter doesn't look right though.
    Also, you don't have to shrink the channels window. You can just click the pin on the top right of the channels pane.
  8. #948
    Dec 2014
    Terrell Tx
    478
    Quote Originally Posted by Keith@HPTuners View Post
    Yes sir I have added it but it is pinked out when I go to graph properties and wont log it. How do I unpink it?
  9. #949
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Road View Post
    Are you logging in the Channel Table the LTFT and STFT (Sensors)?
    Ed M
    [email protected]
  10. #950
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    You can't and don't NEED to add math parameters to the channel list. If you're logging the parameters used in the math parameters then they will just work when used in graphs/charts/gauges.
    Looks like you've made a graph correctly and added it, you just need to delete out what you have in there for a filter. Leave it blank. The proper way to use that would be if say you only wanted your graph to include data that was taken @ WOT or when RPM's were over 4000 RPM's or something like that. It's a way of filtering out data you don't want... It is not where you put the formula for the parameter you want to actually log in that particular graph.
    Make sure you are logging long term and short term fuel trims for both banks in your channel list (can't really see it in your screenshot) and it should work just fine
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  11. #951
    Dec 2014
    Terrell Tx
    478
    Thank you
  12. #952
    Dec 2008
    on the Dyno
    1,825
    Yes I know it loads all data by default however I'm talking about clearing the data as I'm logging within the Histogram. I guess I'll just have to make it a point to kill the log and start a new one anytime I want the populated data cleared.
    Located in Central Kentucky
    ShorTuning
  13. #953
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah just hit stop logging and start back up again. Should work pretty quick if you're already connected
  14. #954
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Ok here is my opinion on a couple of things...
    First, for those of us that make our living using HP Tuners, there is a bit of panic when we update the software, and it is not exactly what we are used to. Time is money when tuning professionally, so it does place a bit of pressure on us. Especially when there is a learning curve with the product.
    All in all I am pretty happy with the 3.0, the scanner is light years ahead, it is different, but once figured out, it is very powerful.
    I have a couple of requests on the editor.
    Every time I update, (daily) the units don't always carry over. Now I'm not talking about the main Imperial/Metric option, but rather individual units. For example, on the transmission portion on a GM, the pressures default to kpa, where I prefer psi. I have to manually change them one at a time. Never seemed to be a problem with 2.24, and not nearly as often in 2.25.
    Also when in 2.24, I would have my maf table setup to display on the horizontal split, showing the editable table and the 2D visual part of the table. Since 2.25 it defaults to no split, and you have to drag open the split to see the 2D visual part. I prefer it opening up the way I use it.
    Finally on the scanner,commanded gear does not work at all in all the 3.0 versions including 3.0.23. Here is a video of me trying it. It goes right on through the gears automatically. This is on a 2013 Silverado, I have tried it in 2007-2013 Silverados with no luck.
    https://youtu.be/2qM1wrm8koI
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
  15. #955
    Sep 2002
    Chicago, IL
    6,397
    I believe you can set it to view range only, and then adjust your view scope. I *think* if you do this, your histogram will always be fresh data only.
  16. #956
    Feb 2016
    Dallas, NC
    39
    i hope support can help me out with the crashing and logging issues. while logging today the scanner stopped logging information about 1/3 of the logs I tried to do and crashed without option to send report 2 times in about 2 hours
  17. #957
    Apr 2009
    25
    What version of 3.0 are you using?
    Have you tried repolling for supported parmaeters (under the Vehicle menu)?
    Keith, I have tried repooling. I am on the latest version as of yesterday. I do not have my laptop handy to check.
  18. #958
    Dec 2008
    on the Dyno
    1,825
    Understandable there as well. Just having to break myself from the old scanner is all. Once I get the motions down I think it'll be fine as is.
    ShorTuning
  19. #959
    Dec 2014
    Terrell Tx
    478
    I didn't add that to the filter I used a couple days ago and worked fine. Don't know how it got added to the filter must have done when it converted from 2.24. Thanks again for the help.
  20. #960
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    In the editer, this unit wont change from mV. The unit will change to V from mV, but the numeric value stays the same. Most of the others switch properly... havent tested them all..
    2016 Silverado 5.3
    I know, pretty valuable feedback! lol
    In mV
    in V
    ZL1 Wheels/Tires
