Page 23 of 87 FirstFirst ... 131920212223242526273373 ... LastLast
Results 441 to 460 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #441
    Advanced Tuner 383_Stroker's Avatar
    Apr 2009
    258
    You mean, the PREVIOUS gauge layout?
    If you hit x to close, you'll keep whatever changes you made.
    This is where 3.0 differs than 2.24 though. You CAN save individual layouts from displays (gauge/chart/graph) for future reference, or you can save the entire layout as a whole (using the tool bar buttons at the top).
    Those open/save icons in the Layout Editors are only for saving off-line copies of the layouts for sharing/archival purposes.
    see here: http://www.hptuners.com/help/vcm-scanner/index.html?gauge.html
    I mean, I accidentally closed my gauge window without saving my changes (while still having the scanner open, i only closed the gauges). Then, the only thing I could figure out how to open was a page of default gauges.
  2. #442
    Sep 2002
    Chicago, IL
    6,397
    Ok, in that case, there is no way to restore it, unless you've saved your layout.
    Saving layouts is easy in 3.0, and is separate from Channels.
    Save your Layouts (using the icons on the toolbar at the top) for your various tasks (idle, wot, race, etc..)
    Save your Channels for your various vehicles.
    We got this guy Not Sure, ...
  3. #443
    Oct 2014
    3
    Quote Originally Posted by Srtboost4u View Post
    Same issues here.
    Attachment 56035 Attachment 56036
    As you can see everything is configured the same but the ltft graph only populates the top row while the ltft + stft populates the appropriate row.
    I am having the exact same problem. When I open old logs (2.24 logs), all of the cells fills correctly. When I open a new log, it only fills out a a column or row as pictured.
    Either I have a setting wrong. Or it doesn't read the log correctly. Could be a major bug or user error.
    I guess it's a channel issue. Does the car have to be plugged in to add new channels?
  4. #444
    I can't seem to lock a 98 Camaro in 3rd for a dyno run. I had no issue with this car using the old software. How do I fix this?
  5. #445
    Apr 2009
    258
    Haha, thats why I was saying an are you sure pop up would've been good. No worries though, save early, save often lol
  6. #446
    Oct 2014
    3
    Quote Originally Posted by umrdyldo View Post
    Well I guess I found it. I have a Cobalt SS Turbo. By putting the key in the run position i was able to see available channels. Then i had to add in new channels. For me this included herz for the MAF. Once I added that channel to my scanner, it starter showing up in logs. And fixed the graph issue where it was only showing one column or row.
  7. #447
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by MADWHIP View Post
    This should work in tomorrows 3.0
  8. #448
    finally got a chance to play. gotta say, I like the scanner. I found it alien during the beta, but after getting some time on it tonight, it's way easier to set up.
    here's what I don't like. twice tonight, scanner hangs while logging. 1st time happened before I saved anything.
    2nd time while driving. lost the log both times.
    the application window grays out, not responding and has to be forced to quit.
    reopen, try to connect, says it can't find the interface.
    unplug and reconnect the USB cable, no change.
    unplug and reconnect the OBDII cable, and it connects.
    scanner 3.09, E38 (2010 Camaro LS3).
    fresh install of windows 10.
    not sure what other info I can give you to help you make it stop?
    thanks in advance.
    please make it stop.
    eta: I was able to log just fine a number of times tonight as well. this is intermittent and unpredictable.
    2015 Cadillac Escalade ESV, 6.2L L86, 6L80e - AFM disabled
  9. #449
    Sep 2002
    Chicago, IL
    6,397
    FunkedOut,
    If you forgot to save your logs, Scanner saves every long when you stop scanning to My Documents\HP Tuners\VCM Scanner\Logs.
  10. #450
    May 2010
    Behind the wheel
    272
    Quote Originally Posted by FunkedOut View Post
    thanks in advance.
    I've had the same intermittent issue since late in the development of 2.25 and I can't for the life of me find a pattern. I've tried different vehicles, different installations, renamed my old HP Tuners folder, deleted all my math parameters, with and without wideband, totally stock install settings, etc.
    Sometimes I get 20 minutes of logging and other times I get two. Today for the first time I had the wideband stop responding mid log. Closing the scanner fixed it for the moment. Of course I'm driving and didn't notice I was wasting my time logging.
    When the scanner hangs the CPU goes to 50% on the application.
    Beyond this, I love the new look / functions.
  11. #451
    nice feature.
    I lost the logs because the application hung mid logging session.
  12. #452
    something else I observed...
    not sure if it's real or not.
    Logging with the engine off, key in the run position.
    I was picking amongst a few TPS and ACS channels.
    I noticed when I depress the accelerator, the LTFT's increase from 0 to about 5% and back down when I let off.
    Is this real? Or a glitch? Never noticed it before.
  13. #453
    Oct 2014
    22
    Hey guys,I gave the 2.24 another name so I can keep it and downloaded 3.0 version..i want to use my 2.24 VCM scanner..what do I need to do?it does not verify my vehicle..the 3.0 scanner is working,but my 2.24 scanner isn't...thanks
  14. #454
    Apr 2014
    360
    sorry if this has been asked, but have we lost the ability to update vins in the tunes?
  15. #455
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Log fuel trim cell and see if it's putting you in a different cell when the change happens (for whatever reason). May just be something the ECM has remembered from earlier driving
  16. #456
    Jul 2012
    Italy
    219
    3.0 should be much more region friendly than 2.24. If you do find any issues though, let us know and we'll fix them!
    i sold my corvette and cannot check quickly...is there anybody who can check from Europe?
  17. #457
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    Found some hiccups with the gauges.
    It seems that if you set a range that spans most of an elliptical gauge it'll take the shortest path from the start to the end.
    Also, if you change the max limit on a guage that has a min greater than 0 (didn't check less than 0), the min will be set back to 0 on the guage, but not the editor, until you re-define the min in the editor.
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
  18. #458
    When will we get Kr and TCC on the ram ngc3?
  19. #459
  20. #460
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Originally Posted by VYSSLS1
    can you make it so it DOES NOT auto open the file every time you open the software. its a pain in the ass, it slows it down and for people like my self that are doing different cars every day its a pain..
    You can disable that in the Tools->Options menu
    my does not give the option
    only gives
    system of units
    and
    tuner/autolock
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
