Results 1 to 4 of 4
Thread: Data needed
    Data needed
    I m tuning a car with these "ebay specials". Does anyone have some good accurate data? I am finding conflicting info.
    I tried.
    48.49 48.80 49.11 49.42 49.67 49.98 50.29 50.60 50.84 51.15 51.46 51.71 52.02 52.27 52.58 52.83 53.14
    I also tried
    42 straight across
    Design: Bosch GEN III EV1 Style Fuel Injector
    Interchange Part Number: Bosch Wide Body 0280150558 0280155968
    Spefication:
    Coil Resistance: 12 Ohms / High Impedance
    Static Flow Rate: 42 lb/hr = 440 cc/min @ 43.5PSI ( 300kPa )
    Gain: 0.12ms/MG
    Offset: 0.055ms
    Turn on time @ 14VDC: 1.14ms
    Turn off time: 0.85ms @ 300KPa
    Amperage: 1.0 Amps
    Pressure: Min 30PSIG/ Max 100PSIG
    Length: 3" (74mm)
    O-Ring Diameter: 14.5mm
    Now I know he is not the only guy with these, I see they sell hundreds of these. No takers?
    405
    2,326
    Why would you try 42 straight across? Is the vehicle using 43.5 psi fuel pressure with a vacuum referenced regulator and a return line?
    Quote Originally Posted by 2xLS1 View Post
    No, it has a regulator near the fuel rail. But I left it with the info the first line I had used to scale with the excel program. I just wanted to make sure the info is correct with the first line.
    Trying to see if someone was using the same or similar.
