Ive been working on a 79 camaro that we ls swapped with the drivetrain from a 2004 gto. The only modifications that have been done to the motor are headers, holley single plain intake and then it has a holley throttle body. The part number for the throttle body is 534-588. The car does not have a MAF so it is speed density. The IAC that holley uses is a chrysler style. i have wired it according to holleys instructions. well i have been trying to tune idle for about a day now and im having no luck it always wants to idle around 1000 rpm. and it seems to be running lean at idle i do not have a wide band to confirm this. I talked with holley and they gave me parameters to put in to hp tuners but i do not know what tables to actually enter them in to. I have attached my current tune im working with and the info holley gave me. any help would be appreciated.
INFO FROM HOLLEY
Internal.Idle.Config.MainP= 18
Internal.Idle.Config.MainI= 32
Internal.Idle.Config.MainD= 60
Internal.Idle.Config.IACBlankingWindow= 40
Internal.Idle.Config.DBlankingWindow= 40
Internal.Idle.Config.LowsideEnablingRPM= 100
Internal.Idle.Config.LowSideP= 30
Internal.Idle.Config.LowSideI= 50
Internal.Idle.Config.LowsideD= 60
79 camaro sd 1.hpt
