I read and flashed it successfully. It's licensed and runs fine. But the CEL is on but with no codes.
Update: Code is u0141 communication lost with bcm a/front bcm no communication. This would make sense if the body control module wasn't functioning but everything from heated seats to a/c to wipers to tcs to lights work perfect. I can't clear it either. Have not tried unplugging the battery yet but will try that tomorrow. Also got comm loss to tcm pcm which is expected upon flash. But I'm rather confused by this one. I'll probably try flashing back to stock if the battery reset doesn't work.
