Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 181
Thread: V3 Scanner External MPVI channels freezing
    Having issues with the V3 scanner MPVI channels freezing after some period of time. Have to disconnect and reconnect to get the channel back online.
    Sep 2002
    Chicago, IL
    6,395
    Another user reported this issue as well, and I'm working with him via support.
    If you remove the MPVI Input Channel, it works fine right?
    We got this guy Not Sure, ...
    Tuner jimbos'ss's Avatar
    Aug 2007
    Killeen, TX
    161
    Mine is doing the same, I thought it was just my WB crapping out.
    2001 Z06
    JCR fabbed Twin Turbo
    Sep 2002
    Chicago, IL
    6,395
    This is a known issue that we're looking into.
    May 2010
    Behind the wheel
    272
    Well darn. I've been trying to track this for ages but thought I was crazy or on my side.
    Sep 2002
    Chicago, IL
    6,395
    You guys are only having scanning issues if you have an MPVI input in the channels display, correct?
    If you remove the MPVI input from the channels display, it works ok right?
    May 2010
    Behind the wheel
    272
    I thought I tried that but I honestly can't remember. I'll remove the input from my next log and let you know.
    May 2010
    Behind the wheel
    272
    I made several logs this evening after removing the MPVI input and the scanner never locked up. I created a few logs in the two to five minute range, a 20+ minute log and a 30+ minute log without a single problem.
    Jan 2006
    Naperville, IL
    94
    Same issue here...
    Rob
    2017 Chevrolet SS 6mt LSA
    Prior - 2015 Chevrolet SS 6MT LSA
    Old - 1998 BMW 540I Supercharged 402 LS2/T-56 swap
    Older - 1992 BMW 325i 402 LS2/T-56 swap
    Very old - 1995 BMW M3/ 402 LS2/T-56 swap
    Sep 2002
    Chicago, IL
    6,395
    This is a known bug.
    We just put up VCM Suite 3.1.17 BETA to test, it might solve this issue. We need feedback. Please contact support and request access to the beta in regards to this bug.
    If this solves the issue, we'll merge this fix into the 3.0 build.
    May 2010
    Behind the wheel
    272
    I did a 24 minute log with the wideband and no problems so far... I'll run a few longer logs and see what happens later this evening.
    May 2010
    Behind the wheel
    272
    Just got the opportunity to log an hour and a half without issue using the 3.1.22 beta.
    Jan 2006
    Naperville, IL
    94
    Great news, I look forward to the fix being folded into 3.0
    Rob
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by gofastwclass View Post
    So 3.0 doesn't work for you, but 3.1 BETA does?
    Once again, we have received no feedback for the fix we've added to the beta.
    May 2010
    Behind the wheel
    272
    Well, darn. I spoke too soon. I just had a lockup at 3:47. I'll keep you posted.
    UPDATE:
    I sent an infolog to support. I also gave my name here and a link to this thread in case there is any question.
    I just realized this lockup was different in that the application actually saved the file I recorded and didn't go unresponsive / 50% CPU as before. I simply closed the application, place the laptop on standby and went inside assuming the log didn't auto save.
    My very next log was around 5 minutes and worked fine.
    Sep 2002
    Chicago, IL
    6,395
    That doesn't tell me what version you're using.
    Still zero feedback from users that are testing the fix we've added to the beta.
    May 2010
    Behind the wheel
    272
    Sorry, can you not see the emails to support?
    The version I used today was 3.1.22.
    Let me know what you need or want me to try and I'll get it to you.
    Sep 2002
    Chicago, IL
    6,395
    Ok so the new beta is NOT working for you.
    After you see the scanner MPVI inputs stop. disconnect the scanner, then e-mail the debug.dat file to support with a description of what you saw, and we can look into it further.
    May 2010
    Behind the wheel
    272
    Will do.
    May 2010
    Behind the wheel
    272
    Keith, I just sent another email to support with some additional data. Support #26242.
    In this instance the scanner stopped displaying live data, but it did not stop logging. This is in Beta 3.1.25.
