Has anyone figured out what controls misfire minimum timing?
Figured I would bump this back up in case anyone can shed some light on it.
Basically under light throttle and cruise regions. Once load gets to around 25 percent the misfire minimum timing seems to drop into the negatives where it won't affect anything.
I have found in the past with other software is if the timing is too low I would get misfiring as I rolled into it. If you turn off pre-injection without advancing the main enough you get the same type of results.
