I see you can add a channel for Innovate SP2 and I tried all of them with my LM-2 and when I started the scanner they just disappeared. I don't see a way to configure the serial interface in the VCM 3.0 scanner. How do I get the LM-2's serial data to the VCM Scanner? Maybe I'm missing something. I also fired up Logworks and was able to see the serial data so I know it's getting to the computer. I was testing it out on a Dodge but that shouldn't matter. I'll try whatever you suggest if it's supported. Thank you. BTW I was using the 3.0.13 release of VCM scanner.
