Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: 04 stock tune w/ enhanced logging applied
  1. #21
    Dec 2013
    Down Under
    168
    Is it swapping from one main timing table to the other?
  2. #22
    Feb 2009
    277
    I don't think so. The main pulse base timing and low air Dens. Tables are very similar and i am seeing a 10* variance. I thought the difference was related to the OS extended datastream upgrade but now I'm thinking possibly it is related to IAT and IAT coefficient adder tables. I am seeing a large swing in base injection timing with small IAT change.
  3. #23
    Feb 2016
    5
    Here are stock logs from this morning
  4. #24
    Dec 2015
    43
    I see the same thing happen. I have not found which table effects it yet. This time of year having the timing limited that much by IAT really shows up. If I make back to back runs, the first one will have low timing (not good), and the second one will be very close to the value in the base table. It shows as running normal in the limiter. Still looking for the reason.
  5. #25
    Quote Originally Posted by paulb View Post
    So you are saying you are seeing lower actual timing instead of too high of timing Paul? Or are you seeing a combination of both?
    What year of truck?
    Can you post your most recent log showing what you've got going on Paul?
  6. #26
    Dec 2015
    43
    Actual timing is lower when IAT is cold. I have not seen it going higher.
    It's a 2005. I'll post a log later.
  7. #27
    Apr 2014
    704
    I find it strange that the stock tables call for so much more added timing when engine temp and IATs are higher.
    I mean, I have a limited understanding of diesel tuning, but it seems to me that you would want extra timing in colder temp (both ECT and IAT) conditions, rather than warmer conditions.
    Is my thinking flawed?
    I mean, the pilot coefficient table for ECT x IAT in the '05 calibration is multiplying most of the adder table by 1.0 to 1.2 in the colder temp ranges. But the moment you hit 180*+ ECT and 90*+ IAT, the multiplier jumps to 5 and as high as 7.
    And it's multiplying against adder table values as high as 15*+ and then base table values as high as 52*.
    So, with a base table command of 52, then the adder table value of 15 being multiplied by the coefficient of 7, you could be seeing as much as 157* pilot BMI (7*15+52=157).
    That is, unless the table doesn't function as I'm seeing it.
    But last night, I was seeing 82.5*+ pilot being logged in the scanner. After some conversation, I went and remapped the adder and coefficient tables so that pilot timing would be more reasonable, and afterwards was seeing 43.5* pilot in the scanner instead of 82.5*.
    I've digressed, but again, I ask, doesn't it seem backwards to add so much extra timing in warmer conditions rather than in colder?
  8. #28
    Strange. My 2004.5 follows my main timing table pretty much no matter what the ECT is.
    What is your ECT when you are seeing the timing being low?
  9. #29
    Dec 2015
    43
    ECT is not the issue, it's IAT.
  10. #30
    Tuner 2007 5.9's Avatar
    Feb 2015
    Nor Cal
    93
    Quote Originally Posted by B00STJUNKY View Post
    Warmer air is less dense, therefore you need more time to compete the combustion process.
    Les Szmidt
    Silver Bullet Tuning
    HP Tuners BETA Tester for 2003-2005 Cummins
    [email protected]
  11. #31
    Feb 2009
    277
    I am seeing the opposite on this early 04. The timing seems to run higher with cooler IAT and as temps increase above 70* timing decreases to base timing table values.
  12. #32
    Feb 2015
    Nor Cal
    93
    Quote Originally Posted by superwagon View Post
    I see it more based on ECT vs IAT on the early trucks....
    Les Szmidt
    [email protected]
  13. #33
    Dec 2013
    Down Under
    168
    Quote Originally Posted by 2007 5.9 View Post
    But isn't it also true that warmer air means less lag time between SOI and start of ignition?
  14. #34
    Feb 2009
    277
    I reduced the Coefficient table to Zero in the 60-70*F range and got another log from this morning. It looks like He is getting some added timing with cooler ECT like Les suggested but as ECT comes up and IAT hits 60*F I am getting close to my Base commanded injection timing. So It does seem that these early trucks are very sensitive to IAT and also ECT. I can not understand why the IAT at say 60*F is so aggressive with timing though? To go from say a IAT of 75*F and 5* base timing to a IAT of 60*F and timing at 15* seems crazy? I see on the later trucks this coefficient table is zeroed out, probably why I never seen anything like that on the 06-07 trucks with the other tuning software.
  15. #35
    Same at not long after start up:
    Your at 20mm3 & 750rpm
    Main timing base map at 37mm3 and 2000rpm gives you about 3.1* SOI
    You have a coolant adder value of roughly 7*
    Coefficient value is 0.91
    (7* - 3.1*) x 0.91 = 3.6* of Main SOI
    Scanner shows 4.0*
    Close enough for me.
  16. #36
    Feb 2009
    277
    I know it is running as commanded now. I did not touch any ECT tables. I said that i zeroed the IAT coefficient table in the 60-70*F range. "Now" in that range i am seeing base table timing numbers in my scanner due to me zeroing out the coefficient in that range. With a stock setting in the coefficient i was seeing 15* injection timing at 60*F IAT and approx 5* injection timing as IAT increased to 70*F. A 10* timing variance based off of a 10* IAT change. The ECT adder doesn't concern me at all. It's coefficient goes to zero after 170* ECT which is well below normal operating conditions.
  17. #37
    Quote Originally Posted by Moparmatty View Post
    Scanner shows 4.0*
    So what you're saying here is that you need to subtract the base table timing value from the adder table value, and then apply the coefficient?
  18. #38
    Quote Originally Posted by Kill View Post
    It was the only way the math worked out.
  19. #39
    I erased my first example by accident.
    So here it is again:
    Basically at 2000rpm, 38mm3 and 140*F ECT
    Main timing base table value roughly = (5.1* + 2.1*)/2 = 3.6*
    Main timing ECT adder table value = 15*
    Main timing ECT coefficient = 0.85
    (15* - 3.6*) x .085 = 9.8* main timing SOI
    Log shows 9.6* main timing SOI
