Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: 03 MAP scaling
    Feb 2009
    277
    As long as they are thirsty.
    Jun 2012
    20
    Quote Originally Posted by energetic motorsports View Post
    factory scan tool reads to 50 psi at 4.55 volts and .5 volts is 0 psi. i dont think that you need to worry about scaling in a higher range sensor. unless you want to use a 100 psi as a guage to data log .
    Intention of rescaling would be to offset the ECM's reading of the manifold pressure and run higher boost.
    There is some logic/algorithm in the ECM to control the boost embedded somewhere, but now I see how we make due otherwise.
    Dec 2013
    Down Under
    168
    I wouldn't mind the option to rescale map if they ever include it in a future update. Id like to use a bigger map sensor to save having to install more gauges than I need. I already have an edge cts, and like a clean uncluttered look.
