Ive attached a copy of the start file that I will be using for initial start up, but since this is my first time tuning VE on an LS3 type car, I literally guessed at the VE table. The setup is a 2012 GS Corvette, 408 stroker/LSA heads, ZR1 map sensor, 227/242@116 cam, YSi supercharger (starting out at 12psi, switching to 20 once broken in) and 92# injectors. I have most of the start up good to go, just need a little help if anyone has a better VE table. This is an upgraded OS, so theres no virtual VE.
