Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: HOW TO: Add Wideband reading to a Chart in VCM Scanner V3
  1. #21
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    The afr error is wb-commanded/commanded
    You have plus.
    Ed M
    [email protected]
  2. #22
    Apr 2016
    31
    Quote Originally Posted by mowton View Post
    You have plus.
    Ed M
    OMG wow, I am retarded...LOL I can't tell you how many times I rewatched the math part of that YouTube video LOLOL. Thanks ED! I will try in a few hours and report back.
  3. #23
    Apr 2016
    31
    Well, I am at a loss...I must be missing something Ed. I changed the math and it dropped the WB AFR. Here is a screen shot. What else do I need in the Channels? What "units" should I be using? UGH, this is making my brain hurt...
  4. #24
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    My opinion is forget about AFR error right now
    You need to get the wideband reading properly first. I assume "AFR WB" in your chart is supposed to be a wideband reading?
  5. #25
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by NorCal06GOAT View Post
    I need more info or can take 5 minutes through Teamviewer and isolate the problem. Load the program and email me at [email protected]....
    Ed M
    [email protected]
  6. #26
    Apr 2016
    31
    Correct. The WB works on its own, with the LC-2. Also through LogWorks. I must be doing something wrong connecting it into Scanner.
  7. #27
    Apr 2016
    31
    Will do Ed!
  8. #28
    Mar 2007
    Florida
    3,772
    Ed M
    [email protected]
  9. #29
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Ed to the rescue!
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  10. #30
    Mar 2007
    Florida
    3,772
    Done :-)
    For all, the issue was when you are setting up the WB on a Standard MPVI through the EGR or AC Pressure PCM port, you cannot use the HP Tuners preconfigured WB error parameters. Matt built the AFR error parameter along with the WB through the AC Pressure sensor in the Math Parameters/User Defined location correctly, but the Chart parameter forr AFR Error was accessing the preconfigured AFR error instead of the User Defined. Once we corrected the Chart to use the User Defined WB error parameter it began working.
    Ed M
    [email protected]
  11. #31
    Apr 2016
    31
    Done :-)
    Yeah, I goofed that one majorly! Thanks Ed...I'll post my finding on the Serial Input shortly.
    Matt
