Page 6 of 6 FirstFirst ... 23456
Results 101 to 114 of 114
Thread: HOW TO: Setting up Fuel Trim Graph in VCM Scanner V3 on Virtual VE Vehicles
  1. #101
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Pretty much. A few of these I had to go back and edit pics later to make things more clear, so probably messed up a label or something somewhere along the way when re-creating the setups.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  2. #102
    Tuner Joe6pt0's Avatar
    Mar 2006
    Indiana
    141
    So on stock cam are you guys zeroing out the Cam angle for part throttle and just tuning part throttle at 0 deg VVE? Or are you forcing each degree of angle 0-20 on each flash and tuning 20x VE tables? :0
    Just curious. Seems zeroing out the part throttle stuff and leaving it that way so you only have to tune 1 VVE is the simpliest way.
  3. #103
    Jul 2018
    Texas
    214
    When I pull up the VE table to edit, it has MAP/BARO Pressure Ratio, not MAP. What now? Capture.PNG
  4. #104
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Use pressure ratio instead...?
    The process is the same regardless. Just adjust to match whatever your VE table is in.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  5. #105
    Dec 2018
    South Florida
    31
    You have to hit calculate coefficient before it'll let you go to any of the other tables, so make changes - smooth or whatever you prefer - calculate coefficients - copy the table that is now present - go to next table - past - calculate - next table - paste - calculate - and on and on
    Otherwise you'll lose all of the changes you've made - which sucks :/
    I'm sorry to revive an old post, but since I use this a my go-to reference at times, ^^ This post had me question how I was doing it. So with this method posted, both 3d models for "Manifold Switch Closed" & "Manifold Switch Open" should be the exact same model just as the (DOD) models are the same, correct?
  6. #106
    Jul 2018
    Texas
    214
    Yes, all tables match. I don't have DOD- displacement on demand/cylinder cancellation on my vehicle so all tables match. I assume you will be turning the feature off as most do.
  7. #107
    Dec 2018
    South Florida
    31
    Thanks for confirming DGS.
  8. #108
    Jul 2019
    Slidell, La
    1,9hw
  9. #109
    Jul 2017
    Mid Louisiana
    10
    I just wanted to say thank you so much for this clear, concise and informative step by step procedure. When i purchased the HPTuners MVPI 2, this is what i envisioned a manual would provide.
  10. #110
    Tuner 00GrcyGtr's Avatar
    Jul 2016
    Westfield, IN (Suburb if Indy)
    169
    If you want to tune just the VVE, then yes you do.
    If you want to tune mainly the MAF, then set the dynamic airflow setting much lower at like 200rpm, then switch it back when you are done with both to have the best of both.
    Hey there, I was reading and learning and ran across this post you answered ("do I have to disable MAF?")
    When I read your response, I had never seen/heard anyone else ever mention anything like this, I was wondering if you might expand on it a little bit. Everyone say to "error out MAF", disable several items, then tune.
    From how I understood what you said, you could tune MAF and VE pretty much simultaneously. Is there actually a way to do this for everything except WOT runs? (I'm trying to get WB ordered and installed for this)
    If this is the case, your directions would be quite helpful, i.e. what to do with PE and other items typically disabled for just MAF tuning, and which of these should still be done.
    Thanks in advance, and by the way, can I ask your first name?
    Again, Thanks!
    @5FDP
    __________________________________________________ __________________________________________________ __________________________________________________
    "To explain the lure of speed you would have to explain human nature; but it is easier understood than explained...Speed is the second oldest animal craving in our nature..." -- T. E. Lawrence
    2000 Regal GSE
    2007 Trailblazer SS
  11. #111
    Jan 2020
    VCM Scanner data only in 1.00
    I have setup my scanner the way the steps showed. I am only collecting data in one row 1.00. Am I doing something wrong here? Did I miss a step somewhere? Struggling to get this plotted out properly so I can tune my VVE. Any help is appreciated, Thanks.
    2018 2SS 1LE M6
    2" Long Tubes No cats
    NPP muffler
    CAI
  12. #112
    Dec 2018
    31
    Quote Originally Posted by 18SS1LE View Post
    2018 2SS 1LE M6
    NPP muffler
    CAI
    You need to change your axis to "Pressure Ratio" instead of MAP. Your VVE table is using MAP/BARO (Pressure Ratio)
    Choose Pressure Ratio in Maths
  13. #113
    May 2023
    15
    Thankyou Sir, I wanted this, started on this, found your post and folllowed step by step - works like a dream, awesome.
  14. #114
    May 2023
    15
    Would I be right in thinking this is measuring while in closed loop only? So if you had to open loop coming on real early it would negate the info say after 50kPa as the ST & LTFT are off? If so for narrow band sensors it could be valuable to extend closed loop activation to get a wider picture as such? Thanks
