Regarding the 3.0 Upgrade. I'm sure it's been brought up in the large thread going, but I cannot read 850 posts at this time.
No issues at all with the 3.0 editor. Works great !
The 3.0 Scanner has many issues for me. I keep updating each morning hoping the scanner issues have been resolved, looks like they have not.
Anyone elses scanner for a 14 year old Gen 3 car look like this ? All main gauges not working ?
On the Scanner, working with 3rd Gen LS series for example, the default scanner does not pick up simple gauges like rpm, speedo, ECT, MAP, KR, Throttle position, Injector DC.
Tried several of my old 2.24 config files, none work.
ok attempt #1 Right clicking into Gauges Layout, manual input the first and one of the most important gauges. RPM. Parameter/general/ Click Engine RPM (SAE). Does not work. Tried the other 3 options, (engine rpm), RPM from crank sensor, rpm from cam sensor) none work.
Attempt #2 Engine coolant Temp, tried all 3 options, none work.
#3 Map sensor, no options work.
so again got some issues.
But here is whats strange. I have a log from 6 months ago on a boosted vette, Gen 3 engine. I can read the log with all sensors working just like I was able to do so in 2.24.
SO. Is there an easy fix for this. Sorry if it's a repeat, just thought I would start a new conversation.
Clint
