Page 6 of 6 FirstFirst ... 23456
Results 101 to 103 of 103
Thread: HOW TO: Setup AFR / Lambda ERROR Graphs vs. VE Table (non Virtual VE Vehicles)
  1. #101
    Jul 2018
    Texas
    212
    Tune and Log Files - VVE
    So what tables would I need to set up for a newer vehicle with Virtual VE tables utilizing MAP/BARO pressure ratio on y-axis and RPM on the x-axis? Here is my log and tables. Why do I richen tune when I use paste special - 1/2? Is there a different formula I should be using due to the MAP/BARO ratio table values that I am changing? My log is open loop with EVAP purge unplugged. When I upload a log, does it include the tables/graphs I have made or do I need to somehow upload them also? This is fairly new to me. Thanks for the help.
  2. #102
    Jul 2018
    Texas
    212
    You would set up a chart with rpm on y and use pressure ratio selection under math at the bottom of list for x. Then log your map, baro, and a/c pressure in your parameter list. Make sure the scales match the VE table. Once your logging, the data will log if all the settings match.
  3. #103
    Jul 2018
    Texas
    212
    I have other posts under VE showing my parameters and graphs.
