Results 1 to 9 of 9
Thread: 2015-2016 mustang ghost tune
    any one have a file with this setup properly and working correctly as it is slightly different then the older coyote stuff. or a write up on how to achieve this..
    Oct 2015
    11
    Quote Originally Posted by Mike@majesticmotorsports View Post
    EVC mapped point 1=40
    Evc mapped point 2=40
    IVO mapped point 1=-60
    IVO mapped point 2=-60
    Idle speed(s) 825
    RPM error from desired to begin idle control (not sure of ID in HPT)= 300
    Min mph for idle= 0 (Not sure of ID in hpt)
    You can play with VCT delay also if you want it to come in faster/later from startup.
    These are just numbers to get you started, but its a good start. I use different software so my setup is different. Like I said this should get you started. you can play with the IVO/EVC/idle speed to get the sound you want.
    Youll also have to dial in your fuel trims (I'm sure you know this also)
    Feb 2012
    TEXAS
    634
    Dolsvt00,
    are these the complete steps to setup ghost cams on 2015+ GT/SHELBY GT350? Any updates would be awesome...
    thanks..
    Jun 2018
    Wichita, ks
    35
    Did you have an issue with the mapped points jumping all over? Made some change and it would stay is 1-2 but then jump all over and get a little rough.
    Nov 2018
    1
    Bump for the 15+ gt350
    Jun 2018
    Wichita, ks
    35
    Quote Originally Posted by sbush265 View Post
    Other than needing to work on the fuel trims a little more here is my tune file for 2015 gt.
    seans-GhostCam2.hpt
    Dec 2017
    767
    How does it run Sean ? You told me it worked out but curious to how you liked it .
    Jun 2018
    Wichita, ks
    35
    Quote Originally Posted by Bill88stang View Post
    I really like it. It's something fun to throw on for car meet ups but daily I still use my other tune. Thank you for helping me find the tables I was missing.
    Oct 2021
    1
    Hello friend, I have the same question, which tables did you change to get the satisfactory result? If you can help me, I appreciate it
