removed
removed
Tune with actual data not simulated data!.....Applied Road/track Tuning
What does the "Pump shot gain" function do? I'm trying to sort out a lean spot on E85 while cold, after the first start on a cold morning as I try to accelerate I get a massive lean spot on low load. I thought this function might be able to help if I adjust the figures at low ECT.
I have moved this setting and it appears to do nothing, I assume from the description as the accelerator goes down it adds more fuel?
