I'm posting an update on this just to more or less give people insight and possibly hope... First and foremost - Thank You HPTuners for adding these well needed TB parameters - these will always be needed...
Long story short as we all know or possibly the people with this problem have experienced - all this does is get rid of the REP - still won't do anything for the actual problem - IN FACT if you over shoot the test percentages such as the P2101 code - it can actually make the problem much worse (wouldn't recommend changing this to anything higher than 8 or 9 percent on the plus / negative settings)... AS LONG AS the actual problem is airflow across the throttle blade turning it into an airplane wing resulting in the stock TB motor being unable to maintain enough torque to hold the plate in "it's" commanded position - Nick Williams currently is working on a fix... He actually has two fixes and as soon as things become more readily available, his TB's in general shouldn't ever have a problem with this ever again...
The man happened to be at the half mile runs this last weekend with his prototype - we tested it on our 108TB that was having all sorts of fits with the plate opening and closing on it's own - problem immediately gone
I think a couple of other shops on here may have all ready tested his fix as well - with possibly a 100% fix rate so far? Thank You Nick for getting this sorted out - and in multiple ways - Thank You HPTuners for allowing us access to the necessary tables to deal with this...
