Results 1 to 4 of 4
Thread: 2011 v6 camaro tunes and ghost cam ????
    Feb 2016
    4
    Does anyone have any tunes for a 2011 v6 camero with cold air intake and ss exhaust and maybe a ghost cam?
    Dec 2009
    Bayside, Melbourne, Victoria
    301
    I've seen a file done on the F series ford & been told it can be done with any vehicle with adjustable cams but I haven't seen 1 on the V6 GM vehicles but been told the agressiveness of it can be controlled via the cruise control switch when done right on them too.
    ghost cam is threw trifecta there tunes are locked and you do not want it.. i had them and went to hp tuners much better route
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    you can do the ghost cam on the v6, however it does take a little work. Not quite as easy as the coyote stuff. Ford uses a much more aggressive cam to start with. It does take a considerable amount of cam movement to create the overlap needed to gt the lope. It takes a combo of idle tuning, as well as cam movement to get the desired results.
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
