Can you please add a pid for the 14point7 wide controller SLC PP2?
In lambda and afr please.
0v = 10afr .68 lambda
5v = 20afr 1.36 lambda
Linear
Thanks!!
Linear
Thanks!!
Did you ever get this solved?
Isn't it possible to scale an input manually to achieve this?
I just bought a spartan2 wideband from 14point7 and would expect to be able to calibrate it with this routine http://www.14point7.com/blogs/news/1...and-megasquirt
Which seems exactly like this one, but with a known input to output value https://www.youtube.com/watch?v=jMalD15mOg4
You can set this up yourself regardless... it might not be under the correct name, but it'll work just the same
That's kinda what I thought. Is a PID just a pre-programmed selection? What's PID stand for?
anyone have experience with the 14point7's?
I've never heard of them honestly but basically figure out the formula you want it to use, go through and pretend to set it up as a PLX or whatever but hit the "fx" button and it will give you an option to put in your own formula, and that's pretty much it.. then just use the "PLX" channel wherever needed and it'll work, just will be named wrong for now
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
yea, I'm pretty sure the vid I linked to says that. thanks for the confirmation though
