Page 1 of 4 1234 LastLast
Results 1 to 20 of 72
Thread: SOTF Tuning
    SOTF Tuning
    Any talk about SOTF Tuning for 03-05 Cummins anytime soon??
    Tuner Turbo_Mike's Avatar
    Feb 2016
    Putnam, CT
    130
    Quote Originally Posted by Orange Stroker View Post
    What does that mean? You want the 4 wheel drive to engage in the tune? lol
    2003 305/555 QCSB Cummins
    Piston/rod/sleeve/fire ring/dual CP3/300 overs
    Super Stick NV5600
    S366/S480
    Dec 2015
    37
    He means comparable to EFI Live's CSP5 OS modification.
    Tune switching without a re flash. I for one would love to see live data tuning in RAM for dyno pulls IE, Rail, pulse, main/pilot timing, shift points. Then when you had a table created that achieved the result you save it to ROM for it to be permanent on a re flash.
    I think he means switch on the fly tuning, like a csp5 switch equivalent.
    Dec 2015
    Middleboro, MA
    142
    Quote Originally Posted by Kill View Post
    I think he was saying that on purpose guys
    lol.
    2005 Cummins 325/600 G56 3.73
    Reving to 4800
    Worked Head, Twin Disc, BBI
    Feb 2016
    Putnam, CT
    130
    The only thing I could think of on our trucks that would be considered "shift on the fly" would be the transfer case.
    Super Stick NV5600
    S366/S480
    Feb 2016
    Colorado
    59
    Look up Optimal welding tunes. hes out of Canada and he sells a SOTF kit for the 03-05 trucks only issues is you have to use his tuning. Im thinking about getting it and then seeing if i can put my tunes on it if i dont like his. But its money wasted if i can not.
    2005 Dodge 2500
    80% over injectors, 5" turbo back exhaust, HP Tuners, ARP head studs.
    Intake, Tater Built Turbo 67/67, Fleece 750 Powerflow CP3.
    2.5" front lvl kit, 35's on Soto 20x10s
    Banned
    Jan 2018
    Everywhere
    1,772
    Just do the SOTF yourself if you don?t want to waste the money
    Feb 2016
    Colorado
    59
    Quote Originally Posted by Jim P View Post
    with the early 03 to 05 cummins no one else has a sotf switch available. he is the only guy i have seen that has been able to make it work.
    2005 Dodge 2500
    Banned
    Jan 2018
    Everywhere
    1,772
    Anyone can make it work with what?s available in HP Tuners, all it requires is a little ingenuity
    Banned
    Jan 2018
    Everywhere
    1,772
    If a redneck Alberta welder can figure it out, so can anyone else
    Feb 2016
    Colorado
    59
    yea i am no where near that good i only play with it a little here and there with help from a buddy who is a tuner. been just learning at my own pace.
    2005 Dodge 2500
    Banned
    Jan 2018
    Everywhere
    1,772
    You just need to figure out how/what to tie a SOTF switch in with to make it change which air density table you are running on, each air density table is its own ?tune level?
    Advanced Tuner JaegerWrenching's Avatar
    Jun 2018
    Albuquerque New Mexico
    467
    Can you limit injection events based on air density tables on these dodges?
    I would think that is possible. I know for the CM2200 ECU, there were 5 different air density tables for the main/pre/post injection events. Just zero out the table for the air density. As Jim said, the trick would be finding out the resistivity range of the air density sensor, and getting a radial dial resistor that matches it.
    2019 CCSB Bighorn - Excited HP Tuners finally supported Cummins CM2350&2450 platforms
    Banned
    Jan 2018
    Everywhere
    1,772
    Quote Originally Posted by JaegerWrenching View Post
    Yessir you can.
    Jun 2018
    467
    Quote Originally Posted by jfreemanak View Post
    Just find the air density sensor calibration table and then flip your switch to see voltage on each position and then calibrate the table to match your switch.
    Dec 2019
    24
    I was just tinkering with this and using Jims VP tune on a switch so I could try a few different things for testing. But I didn?t get much data before my transfer case decided it was time for a rebuild. (I?m clearly getting better MPG though).
    Not sure what year the OP is but the 03 and early 04 you only have two options for the main tables. Transient and low air density. You can get the desired result of having multiple tunes but its not as ideal as having full control of all the tables like other years.
    But you can tinker with other tables like Baro limiters A/B and correction tables. Even IAT.
    03/04 there is a dual function inlet air temp/baro sensor on your air filter intake pipe. With a switch and some resistors you can tinker.
    Attachment 98195
    Banned
    Jan 2018
    Everywhere
    1,772
    Quote Originally Posted by Everytime5.9 View Post
    Attachment 98195
    That sensor is present on all the electronically controlled Cummins engines, not just the 03/04 Ram application. The baro is what I would use.
    Apr 2020
    Michigun
    9
    Attachment 98195
    The optimal welding switch connects to the engine harness at the IAT sensor. The IAT sensor is then removed from the equation.
    Multiple tune tune sets are achieved similarly in EFILive on the LML's.
