I can not seem to figure out how to data log. I have everything hooked up and it still won't log. Any ideas
What exactly is it doing? I know on mine half the time I have to disconnect and then reconnect a few times before it starts working.
I too have to repoll several times before it picks up The extra parameters
http://www.hptuners.com/forum/showth...er-Information ... check this out it should help you fix the problem it did for me.
the issue I have is I hook up and it says dodge ram v8......
1) What do you have? Is it a V8 ram? lol
2) Close the scanner and re-open.
3) Click the picture of a car, it will scan for the VIN and available parameters.
4) Click the red circle and data will stream
That's all you have to do. If this doesn't work, there are probably other issues.
2003 305/555 QCSB Cummins
Piston/rod/sleeve/fire ring/dual CP3/300 overs
Super Stick NV5600
S366/S480
I have a cummins not a v8 and that's what is throwing me off itll read all the parameters but wont actually data log for me to review later for tuning
no I have not done that and I was unaware of this. prior to doing that do I need to pull down my stock ecm software into editor?
Super Stick NV5600
S366/S480
