I'm trying to work with tuning in the 3d map, but can't figure out how to rotate the map around. Is there a way to rotate the map around, if so how? If there isn't, is this something that you would be able to add in a future update?
You can just click on it, then that will move it left/right/up/down, then if you click with the other mouse button at the same time you can zoom in and out.
Well...isnt that handy!?
Took me a while to figure this one out! Right click and drag to rotate it around. Click both mount buttons and drag around to zoom in/out. Unfortunately doesn't work so well on a MacBook Pro
I've been using HPTuners for over a year now and never knew about this functionality until 3.0 was released and it was mentioned in the 3.0 thread (this also works in 2.24, by the way!).
