SoloDL CSV Lean Angle
Hello,
I have Race Render Ultimate and datalogging from my SoloDL from my BMW Motorcycle. I do not see a lean angle display object for that, nor can i create one from the CSV input file. How did you guys create the Lean Angle? Thanks
If that data is present in your CSV file, then it should be as simple as this:
1) Click the "Add" button under the "Display Objects" section (lower right on the main preview screen)
2) Choose your desired display type (ie Gauge, Bar Graph, Time Graph, Text Data, etc)
3) Set the "Field" selection at the top to your lean angle data channel
4) Click on the style you want
If you want a gauge-style display for this, I'd suggest scrolling down to the "Steering Angle" style under the Gauge menu, and using that as a starting point. It's already setup to show +/- 90 degrees, which you can adjust via the Range min/max settings. Once you customize it how you like, you can export it into a new file name, to appear in that menu.
