Injectors injecting To wrong cylinder
I have. 5.3 with a 411 ECM flashed to a 99 Silverado I'll get all the detailed info when I get out of work
But the issue I am having is that my injectors are firing for the wrong cylinder
When I disable the number 1 injector it actually disables the number 2 cylinder
this is the pattern
1-2
2-4
3-5
4-6
5-3
6-7
7-8
8-1
This only happens with the injectors the coils are firing fine
the fuel trims get inverses and engine loads up I believe because it is trying to lean out one bank but I turn its leaning certain injectors on the opposite bank
Any ideas wth is going on thanks every one
Reason: More info
