Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Idle-Airflow config help
    May 2010
    250
    Quote Originally Posted by Russ K View Post
    These are my Gen III idle tuning files.
    Russ Kemp
    Thank you Mr K
    Jul 2021
    Russ k configuration
    Russ Kemp
    Hey man I?m trying to get your files to put in my scanner for my base idle airflow, I clicked on the attachment and nothing came up . I have the mpvi2 pro idk if that matters , but thanks man if you can help
    Apr 2011
    3
    Gen III GM V8-Idle Airflow.Channels document not compatible with scanner 4.8.7
    Any chance of update? It would be much appreciated.
    Apr 2011
    3
    Awesome! Thank you.
    Sep 2010
    missouri
    3
    A big Thank you to Mr. Kemp. I've used this cfg file and my engine runs great at idle now!
  6. #26
    Jan 2007
    34
    Quote Originally Posted by cino View Post
    oops, tried to correct typo & deleted my post
    here's a repost of updated configs from v4.8.7
    2004 LM4/4l60e (5.3l from buick rainier), long tube headers, ls1 intake, & airraid intake tube in 68 camaro
  7. #27
    Arizona
    432
    Quote Originally Posted by shanekennedy View Post
    any word if this works with VCM Scanner 5.0.4 ?
  8. #28
    Advanced Tuner Matt Vardaman's Avatar
    Mar 2021
    207
    Quote Originally Posted by bk2life View Post
    It works on the newest vcm scanner.
    2001 Silverado 5.3 - 209/217 cam, GT45 Turbo on 7lbs, Aem x-series wideband, 50lb/hr flex fuel injectors, on E85 with content sensor
    1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
  9. #29
    Arizona
    432
    Quote Originally Posted by Matt Vardaman View Post
    thank you, sir, i was able to verify it as well
  10. #30
    will this work with the 5.7 hemi?
  11. #31
    1,454
    Quote Originally Posted by breonbrazier123 View Post
    Probably need to ask your question in a dodge section.
