Just keeping this discussion updated, in factory form the
throttle body airflow and the desired
throttle small and large tables are 100% inverses of each other. I am assume if I do not want to have the PC correlating my commanded pedal position vs airflow table, these other two tables should be lined up to the new
throttle body airflow table?
Otherwise, I would think I push the pedal to 0.30 volts, computer knows that means I want 126 lb/hr of airflow, goes to the
throttle body airflow table, finds 126 and now sees that as .20 volts. SO I will be left with a log that shows 0.20 TPS voltage and 126lb/hr.
Attachment 57882
