Results 1 to 3 of 3
Thread: Autostick keep shafting
    Jan 2016
    Iraq
    16
    Hi I have 3.6 challenger sxt .. even when im using autostick on the 1st gear its keep shafting to the 2nd then 3rd
    but my friend challenger 2014 sxt when he using autostick on the first gear she keeping it on the 1st just like an R/T
    so what I have to change
    this is my tune file thanks 4 help
    mu.hpt
    Nov 2009
    All Around
    3,149
    setting under
    trans
    auto shift properties
    general
    autostick
    change those settings and test
    May 2015
    1,908
    Theres actually two spots to change this.
    Trans>Auto Shift Properties>General>Autostick>Auto Upshift> set this to "Disable"
    But you also have to make sure your TCM limit isn't kicking in before your engine rpm limit. Looks like your engine rpm is set to 6,600 and your TCM limit is 6,400. So basically even in autostick when setup this way, your TCM is going to force a shift when you hit 6,400. Either lower your engine RPM limit below your TCM limit or raise up your TCM limit (what I suggest). Trans>General>TCM RPM Limit, all your ECT and EOT tables as well.. Make that 6800.
