Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 185
Thread: VCM Scanner 3.2.9+ Serial Wideband Feedback
    Sep 2002
    Chicago, IL
    6,397
    Previous thread: http://www.hptuners.com/forum/showth...eband-Feedback
    Serial input should now work for:
    AEM
    Innovate LC-1, LC-2, LM-1, LM-2
    If you have any of these sensors, please test it.
    Please respond with something along the lines of:
    VCM Scanner version #
    Innovate LC-1: Works
    - OR -
    Innovate LC-1: Doesn't work
    (provide detailed description as to what exactly isn't working)
    We got this guy Not Sure, ...
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    OK so I am new to the serial interface...trying my LM-1 (loaded latest firmware) but I add the channel, input to chart and when I connect/log, the channel deignator disappears and no data is recorded...
    I can connect through my serial to USB adapter and program the LM-1 so COM Port 4 where it is connected must be working.
    Thx
    Ed M
    [email protected]
    Sep 2002
    Chicago, IL
    6,397
    If it dissapears, the SW is not detecting it correctly... and if you can use innovates software to configure/monitor the device, then it's likely our software that still needs work.
    Remember though, only one software can connect to the device at a time. If you have innovate software connected, vcm scanner won't be able to connect.
    Mar 2007
    Florida
    3,772
    I did not have the innovate software running at the time. Went through those steps in the beginning as i was setting up the rs232 to USB drivers. What would you need from me?
    Also.it dawned on me that I won't be able to utilize the serial interface when tune/logging with my Surface Pro 3..
    .only one USB :-(
    Thx
    Ed M
    [email protected]
    Sep 2002
    Chicago, IL
    6,397
    Use a USB hub.
    Contact support and open up a ticket, and I can put something in the beta for you to test.
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by Keith@HPTuners View Post
    Use a USB hub.
    Thanks for the Hub advise and email sent...have a good night
    Ed M
    [email protected]
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    I have 3 of those models, LC-1, LC-2 and LM-2, will test and report back.
    9 sec Montecarlo SS
    Does a usb 1.0 to serial cable work for this? I just ordered one and realized after I did that it was a 1.0 usb and not the normal 2.0. i dont think it would matter but just want to check. after i get it ill report back on aem for ya.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    as long as it creates a com port that follows normal com protocols it should work
    Feb 2016
    7
    innovate LC-2 not working, reads 493.0000 lamda when i read it through the logworks software it reads 1.5 lamda both times key on engine off.
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by Acgrading View Post
    What version of VCM Scanner?
    Feb 2013
    8
    Same for me too innovate LC2 on version 3.0.71
    Sep 2002
    Chicago, IL
    6,397
    If you are having issues, you'll have to open up support tickets so we can trouble shoot what's going on.
    Sep 2002
    Chicago, IL
    6,397
    You guys will need to get tomorrows beta (April 6, 2016) and try again, and report your debug.dat files to support for analysis.
    Feb 2016
    7
    thanks Keith i am using 3.0.72 I will try again tomorrow
    Mar 2007
    Florida
    3,772
    On the road today....will try out .73 and beta .213 tonight when i get home.
    I tried to log with it today on a Tahoe and it wouldnt display the CHART data while logging, but once I stopped and saved the log and then reopened it, the data was displayed? I'll have to check it out when I get home as well.
    Ed M
    Last edited by mowton; 04-07-2016 at 08:39 AM. Reason: Wrote graph in first post should have said CHART...
    [email protected]
    We email support for the beta correct? And does it have to be a serial to usb or will just a serial work and Hp recognize it? Sub is coming but I have a serial port and cable laying around
    Mar 2007
    Florida
    3,772
    Keith,
    Tried the LM-1 Serial Interface via Beta 3.1.216 and Version 3.0.75 with the same results. Sent a followup email to support (ticket #32709) with debug.dat and information fies.
    I was able to intiate logging and see the chart plotting using the Beta 216 on my 04 vette today which yesterday, on a 07 Tahoe I couldn't with Beta 213...Not sure if that helps or not.
    Ed M
    [email protected]
    Jul 2008
    15
    Aem is working with today's build
    Jan 2016
    5
    Is this for the aem 30-4110 wideband
    Quote Originally Posted by Alan 956 View Post
