Non of your ve tables are used. The NN uses the virtual ve aka nn to adjust fuel depending on where the cams are. You need to use the nn trainer to tune it properly. If that was a concern anyhow.
I do pay the trainer and use it only as a last resort if im having issues with the injectors. Fine tuning injectors if getting the pw's down perfect isn't enough.
NN will work fine if you rescale your tables for the additional atmosphere when going FI and you have the injector flow data correctly translated for HPtuners. The biggest issue is the injector resolution in the HPtuner table is really small compared to the whole injector range, so if you have it off by a bit the end result if your calculation/line could be off by 20%_30% either way
The problem with turning it off on VVT/VVL cars is there is not multiple VE tables to account for all the different cam configurations you could possibly have, the modifiers can get you close bit at part throttle you will most likely have transient lag in fueling.
The biggest pain in the whole process are the airflow model and coefficients that cap it based on throttle body air inlet calculated. This forces you to falsely adjust that airflow and then build around PRatio. Weights in the NN should reflect accordingly.
