OK so Im having a hell of a time trying to get CL to run at Stoich, I have commanded set at 14.63 AFR and even when its at a 1.0 modifier it wants to run at 16.0-17.0 at Closed loop, no matter what I do to the program it wants to run super lean.
I just replaced both front 02 sensors I have the rear deleted (LS1 in a Tacoma swap) No CEL everything seems happy.
When I run it in SD tuning mode for data logging I can get the AFRs richer, but once I put it all back to standard operation it goes super lean again.
I have tried adding a lot of fuel to the PE table and can make it plenty rich when in OL, but once it goes CL it goes waaay to lean for comfort.
Shouldn't the actual AFR (verified via Wideband) be stoich when in CL when it says its at a 1.0 ratio?
Im going to do some more testing, but I even loaded a stock tune and it still stays lean in CL operation. I cant for the life of me get it to run stoich!!
Are there any obvious things that I may have overlooked to cause this? If not I will have to save a file to post up, but I would have ASSumed it would want to run close to stoich at least?
My setup:
2001 LS1/T56, 243 ported heads, baby cam (slightly larger than an LS6 cam) stock bottom end. Custom 3" intake and custom headers 1-5/8 primaries into dual 2.5" tailpipes.
Before the Heads and cam it was bone stock and ran in the low 15s AFR when cruising, still too lean, but now its so lean its got to be fixed. Planning on going turbo but not until I get this figured out.
Yeah I know post a log....just throwing this out there for now in case there is an answer that makes me smack my head and have a DUH moment...
