Results 1 to 20 of 29
Thread: OSMOD - Copperhead Mustang RPM Limit Patch
    Oct 2007
    Crawfordville, FL
    2,412
    The latest build of VCM Suite 3.0 has a RPM Limit Patch for the 2011-2014 Mustang GTs. This patch will raise up the hard limiter to around 8200 RPM or so.
    This option is available in the OS tab of VCM Editor.
    Once it is applied, you will need to set the rev limiter to where you want it.
    Typically these cars run into a hard limiter around 7700 RPM. With the patch applied we have tested multiple Mustangs and have gotten at least 8150 without issue (both auto and manuals).
    Eric Brooks
    HP Tuners, LLC
    Apr 2015
    212
    Works! And the thing pulls all the way up. Awesome!
    Tuner TunedByNishan's Avatar
    Sep 2014
    Wood-Ridge, NJ
    106
    I was BETA testing it for Eric and it works phenomenal.
    I tested both Automatic and Manual cars.
    Huge enhancement for these cars!
    www.tunedbynishan.com
    2018 Mustang GT - 10R80
    Apr 2015
    212
    when it didn't hit the hard limiter and just kept pulling? Biiiig smile lol
    Advanced Tuner AKDMB's Avatar
    Sep 2014
    NC
    344
    Do the cams still do as commanded after 8000rpm with this patch? This works the same for manual and auto cars right?
    Apr 2015
    212
    They do as commanded.
    Sep 2014
    Wood-Ridge, NJ
    106
    Works the same for manual or automatic.
    VCT stays on commanded.
    Jun 2016
    What all is need for the f150 to get this patch?
    Apr 2016
    9
    Quote Originally Posted by AKDMB View Post
    My car lost cam timing in the next gear for a couple seconds if I shift above 7950 or so. Ever car is different though. So when datalogging, just look at cam timing after the shift and make sure it's still solid.
    Feb 2017
    TX
    761
    Does the patch need to be applied for every retune i do to my car?
    May 2016
    1,134
    Quote Originally Posted by Thatwhite5.0 View Post
    No. Only one time.
    Feb 2017
    TX
    761
    It worked at first, but Im hitting the 7800 RPM limiter again.
    Mar 2014
    309
    You have a manual trans car. I wouldn't expect it t "revert". Sounds like you may have something corrupt with your files. I would recommend flashing the stock tune back onto the car and starting with a fresh tune using the stock file as the baseline. This may also solve your injector issue.
    Feb 2017
    TX
    761
    Just updating since I noticed my post was here. I've taken my gen 1 up to 8300rpm with my limiter sat at 8400. Between one of the shifts, the momentum of rpm spun passed 8400 which disabled VCT for about 5 seconds. But it didn't tap the limiter.
    And on stock OPG.
    Sep 2010
    872
    And on stock OPG.
    This is because you have hit the hard limiter which is 8100rpm, the soft limiter is 7700rpm, this patch removes that soft limiters letting you rev to 8099rpm. If you rev to 8100rpm or more, even if its in-between shifts then VCT will disable itself, cams will revert to 0* 0*, and it will stay disabled through out about hald of the next gear if you stay WOT. It will eventually enable itself again but it's anoying and you will lose races by doing his. I usually set my shifts at 7800-7900rpm since you can sometimes get a little over rev in-between gears and trip the limiters. If it's a auto you can try and aim for a constant 8000rpm shift.
    Oct 2007
    Crawfordville, FL
    2,412
    This patch has been updated, the RPM limit has been increased.
    Eric Brooks
    HP Tuners, LLC
    Mar 2010
    New Orleans, LA
    630
    what has it been increased to?
    decipha @ EFIDynoTuning
    http://www.efidynotuning.com/
    Arizona
    240
    Quote Originally Posted by Eric@HPTuners View Post
    Do we need to re-patch and do a full write I assume on currently patched 11-14 cars?
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Jul 2017
    529
    Yes, what has it been increased t?
    Also, does this apply to 13-14 GT500?
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Quote Originally Posted by MRRPMBRP View Post
    Take it this is the 9500rpm patch or more that PBD and a few others said was found in the ecu
    2011 Mustang GT TT A6
    1998 Eclipse GSX Awd
