Hi, I'm over in the UK and have a L33 Vortec 5.3/4L60e running in a Mazda RX8. Its been upgraded with a 2004 LS2 cam, LS6 intake, corvette pump, pulley and exhaust manifolds. I started off with a mail order tune (MAF-less as I didn't get one with my engine, a salvage purchase here in the UK. I needed to change the throttle curve, (DBW) shift points and speedo etc so I've bought a copy of HP Tuners. I have managed to make the car far more drivable by altering these small bits. Its been really reliable up until recently when it suddenly started running on 4 cyclinders, with no throttle control - idle only. I'm assuming this is failsafe mode. Looking at live data on an OBD2 scanner showed occasional MAP 'no data' messages and I can't seem to view it in live view diagnostics. I'm seeing rpm, tps etc....
So I have a MAF from a Northstar that plugs into my loom and provides readings on my OBD2 reader. How can I re-enable the PCM to use MAF data and MAP? I'd have thought it would be a tick box, but I can't find it even in advanced.
Suggestions please.......TIA....
Gareth
