4L60E not full throttle shifting into 3rd
Almost new trans,done 2000kms, was changing fine.
New hd clutches, new drum, wide band , Transgo high rev springs, steel pump rings, stage 2 Transgo shift kit.
Wont change into 3rd gear at full throttle unless you back off the throttle.. Ive brought rpm limiter in trans tables down and shift speeds down. Wont change in Normal mode or Performance mode at full throttle. Changes normally when driving normally.
Im guessing its not in the tune but be nice if it was .
Hey was your problem solved? having same issue with 06 silverado 4x4
have you done the math for when your speed and rpm are at the same speed for upshift into 3rd
How does that Work? Can you share the formula for that? I was also thinking that the Full Throttle Enable would have something to do because when 4low is on TPS only reads 81% and not 100%? I have reduces the WOT speed and rpm with no luck
