For some reason the car leaves fine and in the middle of WOT at high rpm we have a side going real lean almost shutting off the injectors (one Bank). Both banks are fine at 25-35 Pulse width at WOT and then Bank 1 will drop to .9 causing car to pop and miss
We are running 160# injectors maxed out. Car is on Alcohol. 50psi base pressure 1:1
Any help is appreciated, Attached is Log in frame 3:17- 3:18 you can see the problem
