Results 1 to 6 of 6
Thread: Please check out my tune for correct injector data, 0411 pcm on an LT1
    Hello all. Ive been trying to get the correct injector data for my tune, they are the bosch green giants # 0280155968 42lb, i know the LS1 runs 58lb fuel pressure and i am running a vacuum referenced regulator, the data in the attached tune comes from FIC and who knows if its correct or not. also can someone check out the rest of the tune overall to see if I am missing something? the engine is a 383, 11.5 compression, 8.7 dcr, 236/242 cam 112 cl it has been installed 4* advanced, right now im in the process of relocating the Maf because i have a very irratic maf signal with the maf very close to the tb, i did have it further away but stupid me had to move it. the operating system is from a 2002 Camaro ls1 A4. I am not looking for a freebie i just want to get this thing running right. i have already purchased 2 mail order tunes that obviously have not worked for me. Please, Please, Please.........Thank you...... By the way, the tune was done with the new version 3.0
    Jim
    nobody has experience with these?
    Feb 2018
    NC
    53
    Quote Originally Posted by capss9c1 View Post
    so you are running a 24x conversion?
    Sep 2017
    736
    post dates to 2016
    May 2018
    28
    I myself would also be interested in the 42 Lbs Green injector data if anyone has them. I also am running the 24X conversion on a 383 LT4. Only other way I see I can get the correct information is buy the Greg Banish Dvd.
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    607
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
