Results 1 to 7 of 7
Thread: TH400 swap issues
    Tuner in Training Mods89's Avatar
    Dec 2014
    16
    TH400 swap issues
    Helping a friend out with his car. It is a 88 camaro with a stock 2000 5.3 swapped in. Its originally tuned for a 4L60e. He put a TH400 in it and it runs rough. So from everything we have seen, the tune needs to be modified to think it is a manual and delete the codes associated with the auto trans. So I took a 2000 camaro Z28 M6 tune and swapped everything in the manual section of the trans and trans diag over. I selected the manual selection instead of 4L60e. Then I compared the two files for the codes and changed all the trans codes to the same as the camaro has them set to. Now when we start it, it will not rev past 1500 rpm. If I swap the old tune it, it will rev past 1500. So I know it is tune related. What am I missing here? This is my first time having to deal with a TH400 swap. Ill post the tune later once I get on with that computer. Does someone have a write up I could follow? Am I just a idiot and need to use the segment swapper instead of copy and paste the values? Thanks in advance!
    00 Trans Am: Forged Iron Block 370ci, LS3 heads and intake, LS3 Polluter cam, LS7 lifters, FAST 92mm Throttle Body, Long Tubes with Off Road Y, Magnamouth Cat Back, SLP Lid, Viking Front Coil Overs, Rear 3 Way Drag Shocks
    Apr 2015
    302
    Use the segment swapper. Just changing the values isn't enough.
    13,564
    I've just disabled all transmission related codes, all transmission torque mngt and any limiters that involved vehicle speed with the transmission when my friend put a 5.3 in his rock crawler with a TH350.
    His tahoe computer did not have a OS that could be use with the segment swap.
    Dec 2014
    16
    Ok, sweet Ill try the segment swap. Thanks!
    Here is the tune that I put in it that wont allow it to rev past 1500.
    1988 Camaro Z28 Th400.hpt
    Dec 2014
    16
    It will not let me do the segment swap. I looked through everything. I have all the codes turned off, All transmission torque management turned off, and I do not see anything that involves the vehicle speed in the trans. Also, I'm in advanced mode to view everything. So I shouldn't be missing something. Can someone look at my tune and tell me what I'm doing wrong please?
    Feb 2014
    10
    Go to torque management= abuse = drivetrain abuse and change 1600 rpm to 6000 or higher.
    Sylvain
    Dec 2014
    16
    Quote Originally Posted by 02 Sierra View Post
    Sylvain
    Thanks! That worked!
