We have a race car with a LSx engine using a 2000 F body PCM.
We are installing a sequential gear box and need a method to reduce torque during shifts.
We are contemplating moving to a Motec which has the torque reduction feature built in specifically for applications like this, but since the GM PCM has served us so well for years, I thought I'd try to keep using it. (not to mention it's a lot less expensive)
Anyway, we discussed interrupting the ignition coil circuits, but that is not the preferred method of torque reduction (like using a sledge hammer to kill an ant), but we also discussed interrupting the IAT, which I believe will throw the ignition into a different map, which could be used to reduce torque.
Is this correct? And anybody know if doing this repeatedly (every time there's an up shift) will throw the PCM into some sort of error?
Any input on this would be appreciated.
Thanks in advance,
TonyG
