Hi,
When will the scanner scantool function work again? Yet to find a car it works on.
Hi,
Works fine for me. Use it while connected to the vehicle but NOT logging.
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
you mean can't clear DTC while scanning ? that suck big time
best regards
Has it ever worked that way? I've never tried to clear a DTC while performing another task like logging, but I'd think the two would be mutually exclusive events due to needing to send a command to the PCM to clear the DTCs vs. being receive only for logging.
You could do both in 2.24. I haven't tried it in a while on v3 but at one point you couldn't be logging and looking at codes at the same time.
If it's not working for you, please contact support.
There are no known issues with the DTC window in the latest 3.0
We got this guy Not Sure, ...
I didnt say i was logging. I was refering to reading dtc and it shows no dtc but the fact its in reduced with engine light on says to me it doesnt work.
What version of VCM Scanner are you using?
What vehicle are you working on?
Please open up a support ticket and we can try a few things to get this working for you.
Ok will do,
Holden Colorado 2.8l Turbo diesel. Using Version 3.1.254 beta and 3.0.82
