I set my VE table using the procedure defined in the sticky in this folder and left the MAF table stock. I'm trying to adjust the air/fuel ratio at WOT but modification of the PE multipler vs RPM table does not seem to affect the outcome. As an example, the Fuel/Air multipler reads 1.25, AFR command reads 11.7 for a PE table value of 1.2. I seems to me that the commanded AFR should be about 12.25.
How much of a change to the PE table is typically required move from and A/F ratio of 12.0 to 13.0?
Thanks!
Brad
